markdown-it-container
DefinitelyTyped icon, indicating that this package has TypeScript declarations provided by the separate @types/markdown-it-container package
4.0.0 • Public • Published
CI NPM version Coverage Status
Plugin for creating block-level custom containers for markdown-it markdown parser.
v2.+ requires markdown-it v5.+, see changelog.
With this plugin you can create block containers like:
::: warning
*here be dragons*
.... and specify how they should be rendered. If no renderer defined, <div> with container name class will be created:
<div class="warning">
<em>here be dragons</em>
</div>
Markup is the same as for fenced code blocks. Difference is, that marker use another character and content is rendered as markdown markup.
Installation
node.js, browser:
$ npm install markdown-it-container --save
$ bower install markdown-it-container --save
API
var md = require('markdown-it')()
            .use(require('markdown-it-container'), name [, options]);
Params:
  • name - container name (mandatory)
  • options:
    • validate - optional, function to validate tail after opening marker, should return true on success.
    • render - optional, renderer function for opening/closing tokens.
    • marker - optional (:), character to use in delimiter.
Example
var md = require('markdown-it')();
md.use(require('markdown-it-container'), 'spoiler', {
  validate: function(params) {
    return params.trim().match(/^spoiler\s+(.*)$/);
  render: function (tokens, idx) {
    var m = tokens[idx].info.trim().match(/^spoiler\s+(.*)$/);
    if (tokens[idx].nesting === 1) {
      // opening tag
      return '<details><summary>' + md.utils.escapeHtml(m[1]) + '</summary>\n';
    } else {
      // closing tag
      return '</details>\n';
console.log(md.render('::: spoiler click me\n*content*\n:::\n'));
// Output:
// <details><summary>click me</summary>
// <p><em>content</em></p>
// </details>
MIT
Package Sidebar
Install
npm i markdown-it-container
Weekly Downloads
407,863
Version
4.0.0
MIT
Unpacked Size
20.1 kB
Total Files
7
Last publish
Collaborators
  • vitaly
